SFS hoses bad fit?
Today I tried to install my new boost hoses from SFS. Unfortunately the hose from the turbo to the intercooler is to long so it's sitting at a wrong angle restricting the airflow.
The hose from the metering unit to the turbo is also to long compared to the standard hose.
Anyone else encountered this problem? Think I will have to cut them down to the correct size. What's the best way to do this? Should I use a knive or a saw? How do I get a nice and straight cut
Originally Posted by T28 RST
I had to cut my Samco hoses, the one from the turbo to metering unit
All i did was tighten a hose clip round it then cut round the clip with a sharp stanley blabe, this will give a straight edge.
Good to hear I'm not the only with this problem. Will cut them down when I find the time. First the car has to get a new TÜV (german mot) after it stood unregistered for 18 months in my garage
Originally Posted by 1.9 xr2 on 40's
worth swapping ends before you cut the middle hose
i find 1 way fits better than the other too
The turbo to metering unit hose is specifically designed to only fit one way round...the inlet to the turbo is pointing 'UP' slightly!
Amazing the number of RST's you see with the hose fitted the wrong way around causing a kink in the middle and thus restricting air flow!
Originally Posted by safechav
Mine had to be cut too........those 2 hoses are never right
more so the bottom one, its awful if you leave it as is, very bad restriction.
my SFS hoses i bought for my last turbo were fine!
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
