anyone know wot this is?
rite i explain, i got a spare bottom end wid my series2 wen i bought it, i jus wondered if any cud tell me wot crank and rods i got it in
casting numbers are= crank= DA50828 and other number 865MBA
con rods = HCS8CB
cheers in advance
con rods = HCS8CB
cheers in advance
1 prob was told buy block wen he delievered car he had through da block in wid it n it was american tall block. y i wana know if neway i can tell wot they r by casting numbers tryin 2 investigate it
sorry mate i type it again, when i bought the car didn't know was getting spare block, we he turned up and delievered the car he said there was a spare block in the boot and it was a 1.9 american tall block, know i am not 100% sure it is, which is why i have got the casting numbers of the rods and crank.
Ah right i see (still a little bit crept in towards the end
Just realised u didnt actually state an engine size in that first post, i thought i saw 1.6 lol
I know nothing about the tall blocks, but im sure it is supposed to have a longer stroke, so hence a different crank.
This is a crank i removed a couple of weeks ago from a 1.6 EFI N/A
Same numbers you will see.........i doubt the rods have any difference, length though if anything.
)Just realised u didnt actually state an engine size in that first post, i thought i saw 1.6 lol
cheers defently looks the same as the 1 in this block i got i suppose only other way to find out is to measure the stroke and the bore and calculate the capacity.
Originally Posted by Jano_OddKidd
Marc.
1900 block from SE has 1800cvh rods and Crank
How does the 1.9 block compare to a 1.9 block?? Higher i presume? Cheers
Marc.
