T04 AIRESEARCH TURBO
T04 TURBO UNIT - AS NEW ! Only 2000 miles or less.
Cost over £650 new !
RS500 REPLACEMENT UNIT. T04 (T4)
WILL FIT TO ALL COSWOTRH`s, Escort, 3 Door & Sapphire 2wd / 4wd.
Good for RS owners - 25 psi Boost.
Also note that this turbo has carbon seals fitted so it can even be used on a suck through system on a SU carb.
This Turbo is the real deal and has only been on a engine that was run in all was new at time this is not a re-con unit.
REASON FOR SALE - This unit was fitted to a 4.0l v8 in a sapphire cossey but due to the lack of room there was to much heat so now this is sat spare and supercharger is in it`s place.
£300
Can collect or will post for an extra charge.
Bristol area
Free Counters powered by Andale!
£300
Bristol area
JK12
33
Apr 26, 2021 12:09 PM
