Brakes upgrade
Old May 5, 2006 | 10:12 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Brakes upgrade
i know that there are several ways of doing this for both front and back. What have you done to your series 2???????????? whats best at what cost?
Old May 5, 2006 | 10:19 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
personally,ive renewed the lot,
rear hubs+carriers,shoes and cylinders,springs and clips,
handbrake cable,
recon calipers,black diamond discs+predator pads,
copper lines,and full set of goodridge,new brake servo.
master cylinder was fine.
stops ok for up to 190 bhp .
Old May 5, 2006 | 10:33 PM
SafeChav's Avatar
SafeChav
Ive got a full 2wd set up:
4 pots on the front
disc conversion on the rear.
I paid Ł350 for the lot, came with all discs which were literally new, new servo, master cylinder (although not an RST one ) FULL braided hoses to replace every steel pipe on the car,front hubs with shafts and shocks, rear hubs, got a good deal it would seem
Old May 5, 2006 | 10:37 PM
The Sludge's Avatar
The Sludge
garibaldi
i was thinking of maybe using the ST brakes
Old May 5, 2006 | 10:41 PM
SafeChav's Avatar
SafeChav
From what i hear its supposed to be a good way to go, especially if you want to run standard rims, the downside with my 4pots being i cant get smaller than 16's on.
Old May 5, 2006 | 11:00 PM
JimmyBoy's Avatar
JimmyBoy
I got rear disc conversion and am using Focus RS Bremo 4 pot calipers and 330mm discs.
Old May 5, 2006 | 11:49 PM
DanRSturbo's Avatar
DanRSturbo
I've left them alone
Old May 6, 2006 | 01:36 PM
adamS2RST's Avatar
adamS2RST
300MM Focus ST170 Front's.
273MM Cossie Rear's.
ABS Removed!
Stop's well
Old May 6, 2006 | 02:05 PM
John Laverick's Avatar
John Laverick
ST170 gear is the way to go on the front imo...very good value for money and a decent disc size...I used to have them on mine.
2wd cossie set-up on the back [with a Bias Adjuster!!!!]
Old May 7, 2006 | 01:31 PM
Taylor's Avatar
Taylor
People that have converted to rear discs,do you have to diconnect the ABS?If not how many of you have done it anyway?
Old May 7, 2006 | 01:35 PM
SafeChav's Avatar
SafeChav
Mechanical ABS is shit, most people remove it from standard cars purely for this reason
Old May 7, 2006 | 01:40 PM
Taylor's Avatar
Taylor
Old May 7, 2006 | 01:53 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
cossie 4x4 all round costs fook all from a breakers
Old May 7, 2006 | 09:40 PM
murdoch1.7zs's Avatar
murdoch1.7zs
is the cossie 2wd rear discs solid or vented??
Old May 7, 2006 | 11:44 PM
SafeChav's Avatar
SafeChav
Solid
Old May 8, 2006 | 04:54 PM
murdoch1.7zs
Originally Posted by safechav
Solid
cheers
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
