fuel pressure???
i was told that its not very often that the fuel pressure needs adjusting from standard setting when running greens ... dont suppise you know the standard press.. i no one is wit the vaccum pipe on and one taken with it off??
PassionFords Creator
Standard fuel pressure is 3.5bar absolute. (Pipe disconnected)
Check that when you refit teh pipe with engine idling that the pressure drops, and that when you apply pressure to teh pipe the fuel pressure raises 1:1
Only the mapper can advise what presure the chip requires.
SMILER258
Sep 28, 2015 09:04 AM
