mot for saff on greens in derbyshire ?
well if its set up well it should be fine............unless.......
if its a late spec 4x4 with the cat removed it'll be a problem!!!!
even more of a problem than normal!!
you SHOULDN'T need a friendly mot tester(in this day and age) for emmissions IF your cars WAS runing correctly!
If it's running too rich on idle how do you know it's not bore washing while on the run and causing damage
get it set up 1st m8 would be my advice lol
