Cars back :) ... no more little problem... (updated)
As a lot of you know i've had my car off the road since Christmas due to a goosed turbo and compression loss.... after stripping the engine down we discovered a piston was fooked...
A few months later, with a new turbo, replacement piston (Thanks again Tim), new piston rings, new pro alloy intercooler, new rad, new silicone hoses etc etc ect... we started the car today
Must say a MASSIVE thanks to Manchester Mike, he put a lot of time in and I wouldn't of been able to do it without him, i've learnt LOADS!!
HOWEVER now the problem.... the car is idling at 2000rpms... not sure exactly what is up... just seeing if anyone has had any similar probs... there is a slight hissing sound when I turn he ignition off... one thing i'm thinking is that the inlet manifold has a leak, hoping its not that as it was a pain in the arse as i've had to use a conversion plate supplied by oddkidd.
Must say its great to have it back and will be even better when this is sorted and MSD get their hands on it
Right few checks today....
Its idles at 3000revs today
Sprayed WD around one side of the inlet and the revs dropped for a few seconds so going to take that back off next week and replace the gaskets, hopefully all should be okay then
Was really happy as she started first time on the button
Just a shame about the high revs lol but theres always something!!
Will check for air leaks and maybe re-fit inlet manifold.
I know feck all about efi... what sensors could cause high rev's?
Could a faulty TPS cause the problem?
Right SORTED....
seemed to be the conversion plate that oddkidd supplied... took to my local engineering place and turns out that it was slightly bent
plus scratched (I thought gaskets would have sealed)
.... got them to skim it for me plus I filled the scratch
... new gaskets, back on... SORTED
... for now lol
Time to run it in and give MSD a bell
... for now lol
Wasn't very happy with the overall service from oddkidd
Really made up you found the air leak mate, sounds great now and idles spot on.
Give stu a bell today and try and get it booked in
CabrioTurbo
Aug 1, 2015 11:04 AM
