compression struts?
Old May 4, 2006 | 08:18 PM
Basky's Avatar
Basky
Default compression struts?
are these worth doing if so wot gains would be acheived
this would not be road going either
Old May 4, 2006 | 09:16 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Castor adjustment / control is the advantage.
On a road car - not really worth it IMO.
Old May 4, 2006 | 09:28 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: compression struts?
worth having as long as you still have an arb ....
Old May 4, 2006 | 09:29 PM
Basky's Avatar
Basky
thought these were a replacment for the arb
Old May 4, 2006 | 09:50 PM
THEYGOTMETOO
CUNT!
They are, but you can get front mounted bladed ARB's too
Old May 4, 2006 | 10:16 PM
Basky's Avatar
Basky
has anyone got any pics please
Old May 4, 2006 | 10:59 PM
Azrael's Avatar
Azrael
They replace ARB in it's caster control function, not in anti roll function.
Old May 5, 2006 | 07:42 AM
RS_Driver's Avatar
RS_Driver
Zoo Motorsport has a Kit with the ARB and Struts
"New Generation TCA's, Comp Struts, ARB brackets + fitting kit (std ARB)"
Old May 5, 2006 | 08:20 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if you want the compression struts you will probably also have to think about getting the other bits too, front mounted arb with the drop links, adjustable tca's, strut tops and coil overs
that way you can do what you want with the positioning of the front wheels, and if you say it's not for the road, then you are probaly going to get the best use out of it on the track
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
