spherical top mounts?
what are these?obviously top mounts,but you hear different terms like spherical or eccentric or concentric etc......what are spherical ones?and are they worth having?ive been offered a set for 75 notes on the nova!and i want to know wether to buy them or not.cheers
sperical will mean that the top mount has a sperical bearing in it that the strut bolts to. replaces the rubber shite.
eccentric means that the top mounts can be rotated thus giving different camber adjustments.
they will remove flex fromt the top mounts, but as will all rose joints etc they will give a harsher ride.
if you have coil over then it may be worth getting the eccentric ones as then you can adjust the camber etc
Like Dan said, spherical dont mean its adjustable, just solid.
Need ones like on my SX, or eccentric ones, to be adjustable.
But adj TCAs do the same job (camber) anyhow, and on a FWD you wont want more camber than the TCAs will give you.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
