Good Price Or Not?
Engines: 4 x 4 mountune clubman GPA cosworth engine, fully rebuilt, with motorsport 200 long studded block, WRC head gasket, New GPA escort turbo, high torque exhaust manifold, BD14 SPEC mountune cams, WRC 8 injector inlet manifold and fuel rail, 8 x 403 grey injectors, pectel 8 injector loom, P8 ECU converted to 8 injectors, high torque exhaust manifold, high pressure oil high pressure oil pump with oil spray system, lightened and balanced crank and rods, new water pump, big wing alloy sump, motorsport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, £7300. This engine is un-run and ready to go. All plus VAT.
track.focus'd
Aug 12, 2015 05:53 PM
