STEERING WHEEL JUDDER
Hi I have a 2wd sapph coswortrh its had new discs and pads all round . Its also had the outer tca bushes replaced . But on light braking it still has judder through the steering wheel . Can anyone help me .
Check balljoints on the bottom arm m8,get a big bar inbetween bottom of hub and bottom arm and lever them to check for play in balljoint
Also worth cleaning the hub and the centre of the alloy where it sits on the hubs,if you've got aftermarket alloys you will probably have a spigot ring fitted in the centre of the alloy
Alloy should slide onto hub nice and freely,not be tight goin on
Could be anythin connected to steering though sorry m8,I would get inner TCA bushes polybushed if I was you
i'd get the whole front end polybushed tbh.....my anti-roll bar mounting bushes were the cause of my brake judder under light application of the pedal. Polybush it m8...you wont regret it
Stu.
Stu.
ossie cossie
Sep 21, 2015 05:07 PM
Adam Graham
Sep 6, 2015 06:04 AM
