What bits do i need to go STG3?
Old May 3, 2006 | 07:34 PM
boXXer's Avatar
boXXer
GASH!
Default What bits do i need to go STG3?
My cars currently stg1, but was thinking of going the stg3 route. What bits do i need to do it? i can think of...
500 style intercooler
Dark Green injectors
T34 turbo
3bar map sensor
anything else i need?
Mike
Old May 3, 2006 | 07:50 PM
JamesH's Avatar
JamesH
-31 Actuator
Chip/re-map
TIFF's Avatar
TIFF
Chasing Radders
new clutch
Old May 3, 2006 | 07:51 PM
mk1 chris's Avatar
mk1 chris
i would say a decent oil breather too
Old May 3, 2006 | 07:52 PM
scottbrown's Avatar
scottbrown
BRAKES!
Old May 3, 2006 | 07:58 PM
mk2rstaff's Avatar
mk2rstaff
water seperator swirl pot and some samcos
mattbibs's Avatar
mattbibs
4x4 cooler will do fine for stg3. 500 cooler would be the choice if you loaded tho!
Old May 3, 2006 | 08:54 PM
warleydaddy's Avatar
warleydaddy
Originally Posted by scottbrown
BRAKES!
Well done that man!!!!!!
Such a over looked part of tuning!!!
Pete..
Old May 3, 2006 | 09:03 PM
mk2rstaff's Avatar
mk2rstaff
what minimum brakes would you all suggest, i got grooved discs up front and tarox pads, but std rear
Old May 3, 2006 | 09:28 PM
boXXer's Avatar
boXXer
GASH!
ive already got tarox all round with ferodo 2500's. seems enough for me. clutch is a good suggestion as i was thinking about that.
Old May 3, 2006 | 09:35 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
You know it makes sense
Old May 3, 2006 | 10:15 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
my original clutch deals fine with my stage 2/3. brakes are a GOOD idea
Old May 3, 2006 | 10:23 PM
boXXer's Avatar
boXXer
GASH!
so what spec would i need for around 380ish?
Old May 3, 2006 | 10:25 PM
mk2rstaff's Avatar
mk2rstaff
would imagine your in need of larger ones there mate ap's or similar with pads and discs to cope depending on what you do with the car ie track days.
Old May 3, 2006 | 10:30 PM
boXXer's Avatar
boXXer
GASH!
sorry, i meant engine parts.
Brakes are for pussies! pmsl. They slow you down!
Old May 3, 2006 | 10:43 PM
mk2rstaff's Avatar
mk2rstaff
big turbo t38 hybrid, greys, chip and remap to start mate, but on standard block and head your out of the realms there depends what you had done already. lightening balancing porting big heads cams the list is endless mate
Old May 3, 2006 | 10:57 PM
boXXer's Avatar
boXXer
GASH!
aahhh nah, sod that then! lol. I only want it a bit quicker from what it is now.
Old May 3, 2006 | 11:00 PM
Matt's Avatar
Matt
read the website in your signature
.....and i dont mean the one with the generous rolling road
Old May 3, 2006 | 11:02 PM
boXXer's Avatar
boXXer
GASH!
i read it. Nothing happened.
Old May 4, 2006 | 12:12 AM
bud-weis's Avatar
bud-weis
Football Cwazy
For 380 ish,you'll need a T34,greys and also be good to have Karls stg1 head,although not totally necessary. plus all the bits above. standard engine will be fine if in good condition,headgasket may suffer,so get Karl to wire ring it,job done
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
chowfornow
Sep 19, 2015 10:47 PM
