my FRST compression test results! good or bad!
hi just done my compression tests for my frst and i got 150 accross all 4 cylinders, is this good??
regards
regards
Originally Posted by jayRS
dont sound bad, you got to allow for wear and tear mate.
if you got no probs, dont worry about it
150 accross the board is okay mate you have nothing to cworry about with 150 its strong enough
your only running standard boost on the grey one ain't you?? if so you can hammer it all day long with no problem
what compression results did you get?
remember the red one i had with the comp white wheels, that was running 206bhp and i got 150 across all 4 on that as well!
I had the same the last time i did mine 150 across the 4
XRT_SI mate that don't sound like a healthy engine 120-50 the 120 is low never mind the 50
It wasnt healthy to say the least
When we took it apart found the side of the piston had cracked off and collapsed, apparently due to a boost leak
Got a brand new engine now
borboyous
Aug 22, 2015 11:17 AM
