P8 ECU MA Development Stage3 Chip & Pectal Board (sold)
MA Developments Stage 3 Chip & Pectal Board removed from my Large Turbo Escort Cosworth P8 ECU in perfect working order, removed due to chip upgrade
Kenny@MSD can verify that it is a perfect working item as he was the 1 that removed the board and chip from my ECU today 02/05/06
Chip is setup to run with Bosch 803's & 3 Bar Map Sensor and was running 22psi with T34 on my Escos
I do also believe this is the correct Pectal Board to allow you to run ALS?
£130.00 including Postage within the UK
Originally Posted by silky16v
Originally Posted by SPADGE
Got the cheque today for those vents you tried to stitch me with
Just being curtious
And no i don't
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
