rear discs
Old May 2, 2006 | 06:03 PM
stuart collins's Avatar
stuart collins
Default rear discs
how easy is it to fit rs2000 rear disks on to a s2 turbo do u need any mounting brackets for the calipers or do the just bolt up.
Old May 2, 2006 | 06:26 PM
mercury grey minter's Avatar
mercury grey minter
I,d use cossie 2wd ones .They are a lot easier to fit and apart from the brackets£40 you can all ford parts.
Old May 2, 2006 | 06:39 PM
stuart collins
ive got a rs 2000 im breakin so its easyer if i can use them
Old May 2, 2006 | 06:41 PM
SafeChav's Avatar
SafeChav
Depends how the RS2000 items bolt up etc, because they are two pot non sliding calipers arent they?
I'm not too sure on the handbrake cable either because i know there is a 3 part cable listed for the RS2000's and it doesn't look similar to the standard items.
Old May 2, 2006 | 06:52 PM
murdoch1.7zs's Avatar
murdoch1.7zs
whats every thing you need to do a rear disc conversion. and a rough price
Old May 2, 2006 | 07:37 PM
SafeChav's Avatar
SafeChav
2wd Cossie/Granada rear discs and calipers
Conversion brackets
MK5 RS2000 handbrake cable
And thats about it IIRC
Old May 2, 2006 | 07:43 PM
murdoch1.7zs
where can you i get the brakets from?
how is the brake balance with this when still using std fronts dont want the back end over tacking me when braking. doesnt sound like fun
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
cossirob
Sep 3, 2015 09:17 PM
