fuel pump carrier S2
Old May 1, 2006 | 05:32 PM
spenner's Avatar
spenner
Default fuel pump carrier S2
Can anyone tell me where i can get some of the rubber mountings for fuel pump carrier on S2 and also the big bracket that holds carrier to car as we got a three piece kit from auto specialists and found that there is no bracket in there
Old May 1, 2006 | 05:59 PM
adamS2RST's Avatar
adamS2RST
No your right there isn't a bracket in the AS kit.....you still need the chassis mount and the rubber mounts & nuts and possibly a spare wheel well mount.
You may still be able to get them from Ford. I got mine end of 2004 admittidly but it's worth a try:
Chassis Bracket - F6168055 £27.00 each
Rubber Mounts - F6167524 £4.22 each
Nuts - F1502836 £0.25 each
Hope that helps
Old May 1, 2006 | 06:03 PM
ronf42's Avatar
ronf42
try ford parts uk , they keep old stock from 80's and 90'2 fords
Old May 1, 2006 | 07:29 PM
T28 RST's Avatar
T28 RST
Ok then
https://secure.encryptedspace.com/autospeci...ct_detail&p=161
https://secure.encryptedspace.com/autospeci...ct_detail&p=162
Old May 1, 2006 | 07:40 PM
adamS2RST's Avatar
adamS2RST
That's what he has already bought mate. BUT he needs the chassic mount and rubber mounts that hold the pump in place, they don't come with the kit
Old May 2, 2006 | 07:38 AM
Micky's Avatar
Micky
Jasus,thats a load of bollo!!!Why do they bother only selling half a kit???? Regards Micky
Old May 2, 2006 | 07:44 AM
mercury grey minter's Avatar
mercury grey minter
FORD still stock this part.You can,t buy just the rubber mountings.They come moulded into the carrier plate
Old May 2, 2006 | 09:49 AM
adamS2RST's Avatar
adamS2RST
Because it's usually just the actual 3 peice pump cradle that rots away, and perhaps manufacturing cost's, who knows although the chassis mount can be bad too, I replaced mine anyway...
Old May 2, 2006 | 09:50 AM
adamS2RST's Avatar
adamS2RST
Yes, that's correct, on the part number I quote above I was going on the assumption that he meant the small rubber mountings that actually hold the fuel pump in place
Old May 2, 2006 | 09:59 AM
paulzrst's Avatar
paulzrst
iv got that part in the picture going spare,if i can find it, i got it from a brackers when mine got damaged, but the garage the car was in, made one up by hand.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
