need to know gear ratios and final drive for 2wdsaff gearbox
Originally Posted by cossie4i
What injectors, turbo etc are you using and has your engine been balanced ?
Steve.
Steve.
grays - turbo technics t3(stage 2) - low comp l&b - arp bolts - harvy gibbs head - cams - rs500 cooler - 32psi boost ....ect ect
revs like a motorbike right through the red
You just need a bigger turbo to match the rest of your spec
Steve.
yip i on buying a gt32 hopfully get it next week thyen change the injectors for seimens and im going to change level 6 for level 8 ecu as i want to run closed loop
Adam Graham
Sep 6, 2015 06:04 AM
