idle jumps to 2k when you pump brakes?
Old Apr 29, 2006 | 05:26 PM
AJC's Avatar
AJC
Default idle jumps to 2k when you pump brakes?
hi all, the idle on ym s1 jumps to 2k when i pump brakes up quickly, any idea why it does this, the one way valve form inlet to servo is fine.
im puzzled,
thanks in advance
Old Apr 29, 2006 | 05:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine did that too m8 .
Old Apr 30, 2006 | 12:33 PM
DazC's Avatar
DazC
It will do it if you pump the brakes Andy. You're exhausting all the vacuum in the servo thus allowing more air into the engine. As long as it doesn't rev up to 2k when you press the pedal once (like that silver servo) then there is nothing to worry about.
Old Apr 30, 2006 | 02:17 PM
AJC's Avatar
AJC
cheers daz, just need to sort out the flatspot now
and she now likes her fuel
Old Apr 30, 2006 | 03:01 PM
DazC's Avatar
DazC
I'd get a quick fueling check done on it to make sure it's not running rich mate.
Mine has never been that economical to be honest...
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
