Saff 4x4 pulling to the right under hard acceleration
Originally Posted by TurboShed
Very noticeable when wet, but also noticeable in the dry. Does this mean my front transfer box is stuffed?
C L
Common fault with cossie when ream beam bushes are worn, not sure which though, when you back off it pulls back to the left though correct? When mine pulled under power it was an elongated whole on a bush apparently, never looked just passed it onto a garage to sort.Check with Goodes or other to confirm which bushes it may be?
TPM961
Jan 15, 2018 10:50 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
