whats my problem...
Old Apr 27, 2006 | 07:59 AM
sime73's Avatar
sime73
Default whats my problem...
when it wont start from hot or cold...unless i bridge the fuel pump relay and press the metering head flap down to squirt some fuel in, then it will start after a few turns and tickover perfect.
relay is fine btw, i have to bridge it to put more fuel in
Old Apr 27, 2006 | 12:38 PM
SafeChav's Avatar
SafeChav
Series 1 or 2?
Guessing Series 1 cos i regocnise your siggy
Old Apr 27, 2006 | 05:07 PM
sime73's Avatar
sime73
series 2
Old Apr 27, 2006 | 05:20 PM
SafeChav's Avatar
SafeChav
Sounds like the fuse found in the heated seats slot has blown to me......
15A IIRC?
Old Apr 27, 2006 | 06:32 PM
sime73's Avatar
sime73
oh, what if i dont have that. the s2 engine is in my escort mk6
Old Apr 27, 2006 | 08:19 PM
SafeChav's Avatar
SafeChav
Ummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmm
Bit hard to say then??
What was that other thread of yours i was posting on, wasnt that something to do with starting?
Old Apr 27, 2006 | 08:27 PM
sime73's Avatar
sime73
https://passionford.com/forum/viewtopic.php?t=190210
its not having it from hot or cold now tho
Old Apr 27, 2006 | 09:15 PM
SafeChav's Avatar
SafeChav
Sounds like summits up, did you do the conversion?
Old May 1, 2006 | 02:05 PM
sime73's Avatar
sime73
yep
Old May 1, 2006 | 02:11 PM
SafeChav's Avatar
SafeChav
Hmmmmmmm, how did you connect in the power to the fuelling ECU then? Did you use the KE over voltage protection module aswell?
Old May 1, 2006 | 06:47 PM
sime73's Avatar
sime73
yep, i followed this guide
http://www.retrofiesta.co.uk
click 'information'
click 'mk2 fiesta turbo knowledge....'
click 'wiring guide'
Old May 1, 2006 | 09:01 PM
SafeChav's Avatar
SafeChav
hmmmmmmmm my mate used that guide when he was turboing his XR2 and proper fucked the wiring up.
Bit hard to say really. I personally would check all the connector plugs for the various voltages etc and continuity test everything
Breambasher
Sep 30, 2010 06:27 PM
alansST
Sep 21, 2010 04:51 PM
cwignall
Sep 14, 2010 07:37 AM
Tezla82
Fiesta RS1800/RS Turbo
15
Jun 28, 2006 12:47 PM
