fuel pressure reg
Old Apr 26, 2006 | 08:42 PM
Fiestamatt's Avatar
Fiestamatt
Default fuel pressure reg
hi there just wondering if any can give me some info about a fuel pressure regulator, i think my car is running a bit lean. will fitting one of these and having it rolling road setup solve my problem. R they worth having.
Thanks in advance
Matt
Old Apr 30, 2006 | 11:24 PM
jayRS's Avatar
jayRS
you mean a power boost valve yeah, if so, save ya money!
the fuel pressure regulator as standard is adjustable anyway and shouldnt need adjusting, but if you look at the standard regulator, your see a small round bit on the top thats blank, about 5p size, if its still there, drill it with a small drill, dont give it any shit as its a bit of alloy about 2mm thick, but drill it in the middle with a small drill but be carfull when the drill breaks through, screw in a self tapper and pull the cap off, under it your find the adjustment screw but dont do it yourself as you could make it run lean, but if your going for a tune up they will prb adjust the regulator if it needs it anyway
Old May 1, 2006 | 08:13 AM
Oranoco's Avatar
Oranoco
The FSE power boost valves aren't worth a squirt of piss. Take your car o a good tuner who can set the car up and check your fueling using proper equipment
Old May 1, 2006 | 05:42 PM
jayRS's Avatar
jayRS
i thought i was the only one that knew this
Old May 9, 2006 | 09:33 PM
Stu @ M Developments's Avatar
PassionFords Creator
Nah, theres 3 of us.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dubs44
Sep 19, 2015 06:31 AM
