4X4 COSSIE BITS OPEN TO SENSIBLE OFFERS!!!!!!!
GARAGE CLEAR OUT.
FRONT ANTI ROLL BAR
REAR ANTI ROLL BAR WITH LINK ARMS
ENGINE CROSS MEMBER
1 X FRONT KONI SHOCKER
OIL PUMP & PICK UP PIPE
HEADLIGHTS VGC
REAR LIGHTS (NO PLATE SURROUND)
ADJUSTABLE STEERING COLUMN & STEERING WHEEL
LIGHTENED FLYWHEEL
MASTER CYLINDER
ABS UNIT
SEATBELTS
KIDNEY BOX
OIL FILTER HOUSING
2 X REAR CALIPERS (1 X CEASED 1 X LEAKING) SHOULD OVERHAUL
FUEL PUMP CRADLE
TRACK CONTROL ARMS
AMAL VALVE & PLASTIC PIPES
FRONT SHOCKER CUPS & BEARINGS
PLASTIC HEADER TANK
SPEEDO CABLE
CLUTCH CABLE
BOOT RELEASE CABLE
REAR SEAT LATCHES & CABLES
WILL ACCEPT CHQ & PAYPAL BUT WILL NEED TO ADD 5%.
BRISTOL AREA -CAN COLLECT OR WILL POST, BUT YOU WILL NEED TO PAY FOR POSTAGE.
FRONT ANTI ROLL BAR
ENGINE CROSS MEMBER
HEADLIGHTS VGC
LIGHTENED FLYWHEEL
MASTER CYLINDER
ABS UNIT
SEATBELTS
KIDNEY BOX
OIL FILTER HOUSING
FUEL PUMP CRADLE
TRACK CONTROL ARMS
PLASTIC HEADER TANK
SPEEDO CABLE
CLUTCH CABLE
BOOT RELEASE CABLE
jason_nike
Aug 18, 2019 10:53 AM
Anutternutter
Aug 21, 2015 06:07 PM
