ERST chipped ECUs
Old Apr 25, 2006 | 01:34 PM
PaulT's Avatar
PaulT
Default ERST chipped ECUs
What do they do to a std ecu to chip it? Just remove boost limit and thats it?
I changed the chip on my Series1 and they were like chalk and cheese in terms of power. My original chip is by Turbosystems which runs at 1 bar and the other unknown chip (hearts hash diamond yes i know its the wrong code) ran 14 psi but felt much quicker, could this be ignition related possibly less retarded when on boost.
Advice greatly appreciated
Cheers PaulT
Old Apr 25, 2006 | 02:22 PM
Rick's Avatar
Rick
Hi mate. Yes, the ignition maps can be different - very different actually.
But, u cant compare them directly without changing the base timing (dizzy) as one may be designed to run more static advane than the other.
The way to do it, it to advance the timing as much as possible using det cans
Old Apr 25, 2006 | 05:36 PM
PaulT's Avatar
PaulT
Cheer for that so a trip to the rollers with both chip boxes for back to back runs would be a good idea
Cheers paulT
Old Apr 25, 2006 | 06:45 PM
Rick's Avatar
Rick
Yes, it defo would. But - thats providing ur tuner is willing to experment with the timing, and that the car doesn't get too hot - ie intake tempos and coolant temps are the same for each run.
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
Steve Cooper
Sep 15, 2015 04:39 PM
