Noise from front suspension... Please help!
Old Apr 24, 2006 | 08:28 PM
RST_mark's Avatar
RST_mark
Default Noise from front suspension... Please help!
I've just changed my shock absorbers from non adjustable uprated shocks to a set of adjustable konis. Since changing the shocks i have noticed a knocking noise coming from the top of the front suspension which seems to be more on the rebound stroke when going over potholes and bumps in the road.
I have poly top mounts fitted and am wondering if it could be these which are causing the noise seeing the suspension is firmer, i didn't have any problems with the softer suspension setup and have tried the konis on different settings.
The noise isn't too bad but am thinking of swapping the top mounts back to the normal rubber items to see if this cures it, just wondering if anyone would have any ideas or oppions before i take it all apart again.
Old Apr 24, 2006 | 10:18 PM
NUTS RuS's Avatar
NUTS RuS
Did you put the flat bearing ( a bit like a washer) back on ?
Old Apr 25, 2006 | 09:40 AM
s2rstony's Avatar
s2rstony
i had a prob like this, turned out the spring had snapped!!
Old Apr 25, 2006 | 08:00 PM
RST_mark's Avatar
RST_mark
Yes they were all assembled properly with the bearing, checked all the parts too cos on one of the old shocks the cap had started to spit but used good parts.
Might try and change the top mounts and see if that makes a difference.
Old Apr 25, 2006 | 10:00 PM
Wazzzer's Avatar
Wazzzer
I had this, turned out to be the nut holding the spring cup on had undone slightly...
take the top cup off and see if it needs tightening
Old Apr 26, 2006 | 10:18 AM
RST_mark's Avatar
RST_mark
cheers, gonna do a bit of investigating later
Old Apr 28, 2006 | 04:46 PM
RST_mark's Avatar
RST_mark
Had a look at the car and checked that everything is tight and all is fine, when i have time next week am gonna try changing the top mounts to see if that makes a difference. Can put up with the noise but want it to be right.
Any body else got any ideas??
Old Apr 28, 2006 | 10:33 PM
Andy-ywk's Avatar
Andy-ywk
I had a problem with a set of front koni dampers last year. The spring platform had been mounted on the damper 1 inch further down the damper body than it should have been. Might be worth checking against your old units.
malkiemac3579
Jul 14, 2017 12:10 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
