Series 2 Temp problem (Advice/ideas pls)
Old Apr 23, 2006 | 08:31 PM
CabbyRS's Avatar
CabbyRS
Default Series 2 Temp problem (Advice/ideas pls)
I have a problem with the running temperature on my Rst, i've had the car a year and to b honest i should of sorted this first!! The car seems to gradually get hotter and hotter and would definately run straight into the top of the temp gauge and cook itsself, i do have a switch in-car to keep the fan on permanently which does help somewhat although when im on the go theres enough air flow to keep it cool without,
Its when i come to a stop and leave it runnin, slowly it will creep higher and higher which leaves it very risky when sat in traffic, i've currently taken the Thermostat out which obviously does delay the cooking but also cant be good for the car (mixture wise) so i really need to get somethin done asap, b4 the hot summer!!!!!!
The heads been port & polished i hear this does make a difference but i cant see it making it this bad???
If any of u guys could give me some ideas or have had the same prob i'd be grateful 4 sum help
cheers
Old Apr 23, 2006 | 08:58 PM
T28 RST's Avatar
T28 RST
Ok then
Fooked headgasket
Old Apr 24, 2006 | 12:21 AM
SafeChav's Avatar
SafeChav
As above although if it is gone u should see coolant being lost.....and probably contamination with the oil?
Old Apr 24, 2006 | 08:23 PM
adamS2RST's Avatar
adamS2RST
Don't sound good tbh. And running no stat is not a good way of combating cooling issues. If the fan is not cooling the car down within a minute or so back down to the 1/4 mark you have a problem.
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
Bransby
Sep 11, 2015 01:09 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
Ben26
Sep 3, 2015 07:55 PM
