chip 400bhp+ of the ahmed beyjoo
Old Apr 23, 2006 | 07:29 PM
miguel's Avatar
miguel
Default chip 400bhp+ of the ahmed beyjoo
I information retrieval veiled on chip of ahmed beyjoo for the injector greys to give for 400bhp+. I wanted to know this qu one needs which configuration engine??? which turbo???? which RV??? which camshaft??? thank you
Old Apr 23, 2006 | 09:57 PM
miguel's Avatar
miguel
no reponce??????
Old Apr 23, 2006 | 10:03 PM
cossie604's Avatar
cossie604
Welcome to PassionFord
Its a bit hard to answer your question...I think you mean you have a ahmed chip to run greys but you are unsure what else you need to go with this to get 400bhp??
If so, then I would say proberbly a hybrid T35....a pair of BD10 camshafts...and a good solid standard bottom end. Not sure on what octane the fuel is in your country tho?? So dont know what to say regarding compression ratio....
On top of this you would need to get it set up properly on either a rolling road or more idealy a live mapping session.
Hope that helps..
Stu
Old Apr 24, 2006 | 08:59 PM
miguel's Avatar
miguel
pk thank the reponce, octane is the 98
what the boost????? 30 psi?????
Old Apr 25, 2006 | 07:37 PM
cossie604's Avatar
cossie604
sounds the same as our super unleaded octane.......tbh i wouldnt run more than 25psi with out getting it setup properly...or you could be ending up with large engine repair costs
Stu.
Old Apr 30, 2006 | 10:53 AM
Stu @ M Developments's Avatar
PassionFords Creator
ONLY Ahmed can tell you what is on that chip and thus what engien spec is required. Anything else is speculation without reading it.
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
