SLIGHT PROB
hi guys wonder if some1 could shine a bit of light on a little problem i have well over the past week ive developed a sqeek when turning on tight lock, but this weekend i fitted new discs and pads and done a quick oil change now when i turn on tight lock either way the sounds more than a squeek it sounds more a grinding sqeeking noise any ideas what this could be i know my wheels rub on tight lock right at the back of the arch coz i noticed where it was rubbing when i had the wheels off.
If its relavent when i done my oil change when taking off the old oil filter oil still spill over a rubber gator but i cleaned it up the best but let me know if any1 has any ideas
cheers guys
thanks
A PIC OF MY NEW BRAKES COSSIE 4X4 CALIPERS WITH 2WD 285MM DISC AND REDSTUFF PADS
cheers guys
thanks
The Enigma
Sep 12, 2015 10:12 PM
