FRST misfire when floored.
Old Apr 23, 2006 | 03:42 PM
Ixion's Avatar
Ixion
Default FRST misfire when floored.
Hi everyone newbie here.
Just bought a nice FRST and very pleased with it except for one thing if sat I am in 5th doing about 50mph and floor it power cuts a couple of times (like a bad misfire) then it takes off. If I floor it through the gears it pulls like a train and no problem, any ideas?
Old Apr 23, 2006 | 04:29 PM
jaiscossie's Avatar
jaiscossie
what boost is it running mate? could be boost cut out
Old Apr 23, 2006 | 04:44 PM
Ixion's Avatar
Ixion
It's a completely standard car except for a Mongoose exhaust.
Old Apr 23, 2006 | 05:12 PM
BRAMMER's Avatar
BRAMMER
I'm only guessing with this but by the sounds of it, its likely to be slightly over boosting, has it got a boost valve??? if not try winding the actuator bar IN 1-2 turns and see if the problem is present if not then get it to a tuners for a tune and boost and fuel set.
Old Apr 23, 2006 | 07:19 PM
Oranoco's Avatar
Oranoco
Sounds like it's hitting the overboost. In 5th the boost can spike higher which is what is probably causing it to hit the boost cut
Old Apr 23, 2006 | 07:49 PM
rsmcelroy's Avatar
rsmcelroy
definately overboost. Mine does this and every other FRST i have got into dont worry about it
Old Apr 24, 2006 | 09:14 AM
jayRS's Avatar
jayRS
not true, all frst dont do it, mine doesn't, it has in the past as i played around with it, but it didnt do it all the time.
a standard frst running stand boost etc should not do it, and yeah it sounds like over boost btw.
prob find the actuator has gone a little slack, like above, winding it in a couple of turn might sort this.
Old Apr 24, 2006 | 10:32 AM
boostaholic's Avatar
boostaholic
mine did it as well when i first got it but i changed the plugs and its been fine ever since!!
Old Apr 25, 2006 | 08:58 PM
Ixion's Avatar
Ixion
Thanks for all the replies.
I changed the plugs, leads and disconnected the battery to reset the ECU this seems to have solved the problem.
One more question, what PSI of boost does a standard Fiesta Turbo run?
Cheers.
Old Apr 25, 2006 | 10:00 PM
BRAMMER's Avatar
BRAMMER
8psi is safe enough for standard.
Old Apr 25, 2006 | 10:17 PM
jayRS's Avatar
jayRS
standard set is 0.5 bar, 7 psi
Old Apr 25, 2006 | 11:52 PM
SafeChav's Avatar
SafeChav
I was going to suggest plugs....too late
Oh........h196jne FFS change your siggy im nearly having an epileptic fit here
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
gambo08
Sep 16, 2015 08:10 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
