stage 3 settings
hi
got a 89 sapphire and am about to fit a stage 3, but havent got any settings i.e fuel pressure,c.o and boost pressure.
engine spec:standard apart from 200 block, mongoose 3.5,-31 act, oil breather system and pipercross airfilter.
i have all the parts req'd chip 330 bayjoo,3 bar map,4X4 intercooler and 803's.
can anyone help please
Don't touch fuel pressure as most tuners base there chip on a standard pressure. set your boost to hold 20 psi,and c.o @3% this will be fine for a start,THEN GET IT SET UP!!!!! to avoid problems.
I have found with amed's chips they are DIY friendly usually with a boost limit and plenty of fuel..
Then have some fun
Then have some fun
i'm crying due to the unburnt fuel coming out of the exhaust with an AB chip usually - especially if using a stg 3 chip with a t3 turbo (essentially only a stg 2 Thread
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
