Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
capri 2.8i single leaf springs on a mk 2 escort
Old Dec 12, 2003 | 07:24 PM
fatboyz's Avatar
fatboyz
Default capri 2.8i single leaf springs on a mk 2 escort
as above guys will they fit will they huh huh
Old Dec 14, 2003 | 09:19 AM
the original's Avatar
the original
yeah think they can be made to fit lengthwise, but they will raise the rear up. i once had to put some 3 litre capri leafs on a mk1 it was ridiculously high at the back.
Old Dec 14, 2003 | 09:21 AM
the original
tell us about whether you got that rs prop to bolt to a 2.8 axle flange....
still say it will go...
Old Dec 14, 2003 | 11:44 AM
fatboyz's Avatar
fatboyz
well cheers about the spring info but as for the rs 2000 prop on to the 2.8 axle and 2.8 box well , im not sure if we have a rs prop now but the prop we have dont fit in the box and is miles away from fitting on the rear flange on the axle how do i tell if its a rs prop it come off a 1.1 but it is a single piece ?
Old Dec 14, 2003 | 02:00 PM
the original
if it came off a 1.1 it ain't a rs prop, the bit that goes in the gearbox is too small and so is the flange. proper rs mk2 props have a c.v. joint in the centre, but one piece ones are available, base 1.1 models etc had 1 piece props cos they're cheaper but not as good. have you got a centre mount under the floor of the car?
Old Dec 14, 2003 | 07:09 PM
fatboyz's Avatar
fatboyz
no no centre mount any ideas
Old Dec 14, 2003 | 09:56 PM
the original
yeah get a one piece rs prop....
did you say you was puttin the 2.8 box on a pinto? 'cos it won't fit without modding the input shaft
Old Dec 15, 2003 | 10:36 PM
fatboyz's Avatar
fatboyz
Default gearbox input shaft
cheers for all your help do you know what i will have to do to the input shaft as some people have just said chop an inch off others say chop a bit and then get the end turned down help
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
borboyous
Aug 22, 2015 11:17 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
