Extra Fuelling ??? Aeroquip?????
Old Apr 22, 2006 | 07:59 PM
originalcabbie's Avatar
originalcabbie
Default Extra Fuelling ??? Aeroquip?????
I had my Series 1 set up on the rollers, the engine is capable of 300hp with all the mods etc, but I am finding it difficult getting enough fuel to make the car safe.
Now I have a couple of queries and wonered if the GURUS out there could answer my questions.
1) Are S1 supposed to have a fuel acumulator like the S2???
2) If I increase the fuel line size by using aeroquip or similar make can I increase the fuel pressure???
3) Whats the safest way to get more fuel noting that I have the 5ht injector (turned out ot be a cold start valve so I am changing that for a dark green one.
I need help,, Please help me!!!!
Old Apr 22, 2006 | 08:40 PM
DazC's Avatar
DazC
The S1 has an accumulator under the back near the spare wheel well.
Fuel pipe size isn't an issue to be honest. You'll get about 400bhp worth of fuel down there.
Get a proper MF2 mappable 5th injector that goes into the cross over pipe.
There is other options. You can up the fuel pressure, adjust the electromagnetic fuel pressure actuator if it's not already been done and have the metering unit resprung...
Old Apr 22, 2006 | 09:26 PM
davsmith64's Avatar
davsmith64
a even better answer is to go for efi mate.. change the injectors and get it mapped to match then you should get enough fuel.. im converting to efi and using ford racing injectors..
or if u want to make it up so u can setup your own fuelling go for megasquirt..
Old Apr 22, 2006 | 10:06 PM
notSteveS2's Avatar
notSteveS2
as above mate....
didnt wanna say it first tho in case any1 started on 1 coz i took oddkidds route...
that wud b the best way matey... EFi.... theres loads of different options...
weber
fezzy
mega squirt
to name a few
Old Apr 22, 2006 | 10:38 PM
DazC's Avatar
DazC
I wans't going to suggest the conversion to EFI as I got the impression he wanted to stay with KE Jet. If that isn't the issue, then EFI is far better than KE Jet.
Old Apr 22, 2006 | 10:40 PM
notSteveS2's Avatar
notSteveS2
yea me too.. i go tthe impression he wanted to stick with 5th injector route too mate...
another reason y i didnt suggest it!
Old Apr 22, 2006 | 11:12 PM
Rick's Avatar
Rick
what are "ford racing injectors"
for 300hp, id recommend full efi, but with an mf2 u can certainly do it.
Old Apr 22, 2006 | 11:23 PM
notSteveS2's Avatar
notSteveS2
not a clue mate?????????????
ii use cossie yellows
Old Apr 22, 2006 | 11:30 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Fuel to 300hp with a 5th injector
Old Apr 22, 2006 | 11:57 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I wondering the same. I would hate to imagine the state of the off-boost fuelling with such primative on-boost adjustment.
IMO you can't stay away from EFi at that level.
Old Apr 22, 2006 | 11:58 PM
notSteveS2's Avatar
notSteveS2
i agree.... Mr Brains.... he he
Old Apr 23, 2006 | 06:45 AM
originalcabbie
I know for pushing 300hp that EFI is the way to go, but since I got the S1 I would like to have a go at seeing if I can get some good power out the old metering head!!!
Christian and Becky suggested a 5/6th injector set up they might have but as yet they havnt come back to me on a price for it.
I like EFI but I wanna keep if as close to the original as possible. I will EFI my next Series 2 deffo!!!
Old Apr 23, 2006 | 11:03 AM
Rick's Avatar
Rick
Off boost fuelling? How does 15:1 sound
It's not easy to do, but IS possible
Old Apr 23, 2006 | 11:27 AM
Christian and Beccy
#1 in Spelling Club
Nice one Rick.
As you no doubt know, the amount of work in setting up the off-boost fuelling is far greater than the on-boost, no?
How does it drive at 15:1? Nice and smooth?
Old Apr 23, 2006 | 11:47 AM
Rick's Avatar
Rick
mate, i can't tell i how much of a pain in the arse it is to get the fuelling right. Very smooth at 15:1 The one thing about KE, is the transient fuelling is very very good - it;s an instant response, and the atomization of mechanical injectors is better than efi.
I really want to goto Efi, just for the ease of adjustment. plust things like mild ALS
Old Apr 23, 2006 | 11:49 AM
Christian and Beccy
#1 in Spelling Club
Personally, I wouldn't get too excited about ALS. I have it, but NEVER use it. Well on the odd occassion to scare middle-aged road users in road-rage incidents.
What AFR do you run at full boost? OK, so you might not want to tell me that!!
Did you get my PM last night???
Old Apr 23, 2006 | 11:54 AM
Rick's Avatar
Rick
i did get ur PM mate - got it this morn.
I'll send u full data log of afr if u like
With ALS - my use would be for the twisties - to have a little more go when i first touch the throttle. Down the dual carriage ways etc it's not needed
Old Apr 23, 2006 | 12:02 PM
Christian and Beccy
#1 in Spelling Club
Would be interested in that.
Old Apr 23, 2006 | 04:39 PM
notSteveS2's Avatar
notSteveS2
[quote="Christian and Beccy"]Personally, I wouldn't get too excited about ALS. I have it, but NEVER use it. Well on the odd occassion to scare middle-aged road users in road-rage incidents. quote]
didnt no u cud use ALS with closed loop lambda?
Old Apr 23, 2006 | 04:51 PM
DazC's Avatar
DazC
ALS with fry the lambda sensor...
Old Apr 23, 2006 | 04:55 PM
notSteveS2's Avatar
notSteveS2
dont christian run a lambda sensor????
Old Apr 23, 2006 | 04:56 PM
DazC's Avatar
DazC
Not sure to be honest.
Old Apr 23, 2006 | 05:03 PM
notSteveS2's Avatar
notSteveS2
well thats y i questioned his post... he sed he has ALS... and i thought he used closed loop lambda
Old Apr 23, 2006 | 06:05 PM
Christian and Beccy
#1 in Spelling Club
Im not on Closed Loop yet and you are right, ALS and Lambda sensors don't agree, so I most probably won't be using it atall when we change over fully to Closed Loop.
I currently have an Innovate XD-1 Wideband Reader in the car and we are planning to use that in conjunction with the Omex ECU to control the Closed Loop.
Old Apr 23, 2006 | 07:29 PM
originalcabbie
hey got any idea of the price for the 5/6th injector kit, I got cash waiting for you
Old Apr 23, 2006 | 08:44 PM
Rick's Avatar
Rick
ive seen ALS used with the lambda sensor - im guessing it's either quite mild - or the sensor is replaced quite often.
Old Apr 23, 2006 | 09:21 PM
Christian and Beccy
#1 in Spelling Club
I have it all here, I was waiting for a chance to take some pics of it all. Will let you know ASAP.
Old Apr 23, 2006 | 09:35 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
AROFL! I can't beleiev you did that, proably gave the guy a heart attack
Old Apr 23, 2006 | 09:45 PM
Christian and Beccy
#1 in Spelling Club
That served the old bastard right for trying to cut me up in a filter lane. I'm not sure if he really knew what had happened to him, he certainly hung back after that.
Old Apr 24, 2006 | 01:26 PM
notSteveS2's Avatar
notSteveS2
ok cool...
shame to not b able ot use the ALS tho ay.
mk3ste
Oct 17, 2021 10:09 AM
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
