Spring rates .... coil over for road use AVO-GAZ ???
Like other posts on this topic, I am confused. But I think I have found that people are putting coilovers on for road use without first selecting an appropriate spring rate. Is that possible.
I asked the GAZ guy who advised that stock RS Cosworth 3door kit comes with 325lb front spring and 180 lb rear spring.
I mentioned to him that people say they are too hard.... for road use and that they skip on potholes which we have a lot of in Australia.
He said that a 275 lb spring rate on front should help, but they would still be a little harsh but much better.
As he said the shock cannot be too soft as coil overs by nature have a narrower spring and thicker.... giving less travel before coil bind...
So can anyone advise on appropriate spring rates for AVO, GAZ etc for a predominantly Road use RS cosworth 3 door. Being in Australia we have average quality roads... lots of patch ups on roads... and unfortunately only a few track days... you guys are sooo lucky
Also I am interested in your experiences with coil overs on road use, I would like to get them for this purpose with occasional track days if they arise.... and for show days where people do look under your car
Thanks for the feedback
Are those settings for a normal shock strut set up or coil over ?
That is a lot softer than indicated by GAZ, I wonder if they were concerned at getting coil bind on coil overs with a softer setting.
PS: I have sent an email to AVO asking them what they recommend.
Coil over.
I personally wouldnt worry what the others think - as the 'others' wont be driving your car.
Some like it soft comparing it to how they remember the old set-up and some like a hard race set up so your never going to win.
Here in the UK a spring costs between around Ł12 and Ł25 so its hardly going to breaak the bank if you have to try a softer or harder set is it ?
I agree totally, it is up to me.
I am going for a col over set up, either AVO or GAZ at this stage.
And I agree that the springs are not that much of a cost.
I am now down to working out what springs will be reasonable on a road three door cosworth.
What brand are you running the softer springs on, are they ok on the open road, (I take it you are using them on a sierra) where are you driving ?
Thanks for you help...
Settings were on Bilstein coilovers on a gravel spec Escort Cosworth. Using gravel spec makes a fine compramise for road use as its not too harsh.
More important to think about bump/rebound rates of the inserts rather than external coil rates if you ask me. Also ask your suppliers that question
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
