Joiners (attic flooring)
Old Apr 20, 2006 | 01:10 PM
Mark B's Avatar
Mark B
Default Joiners (attic flooring)
hey well im thinking of flooring ym attic so i can have the garage back an use it what its there for, so any tips of how to go about flooring the attic would be great,
The attic will only be used for storing boxes an xmas stuff so wont need to hold any large weight, so extra supports wont be a problem,
So what would be the best material to use? the house is only a year old so nothing should be rotten in up there,
An would i be best using screws or nails to hold the wood? down?
Im a complete novice at all this so all tips welcome.....
MB.
Old Apr 20, 2006 | 01:21 PM
sandyRS16i's Avatar
sandyRS16i
Get chipboard flooring, either individual or packs, the boards are about 3'6" by 1' wide. They are tounge and grooved to interlock them. The best thing to use are chipboard screws, about 1 1/4" or 1 1/2" in length, probabally M8 or M10. They sould be able to get screwed straight through into the joists, if not you can drill a small plot hole first.
Old Apr 20, 2006 | 01:23 PM
St3V3_C's Avatar
St3V3_C
Tip - Don't screw or nail through all the wires that will be knocking around up there.
Tip - Don't put your foot through the ceiling
Normally use tongue and groove chipboard mate. Screws are better.
Old Apr 20, 2006 | 01:26 PM
Disabled Account's Avatar
Disabled Account
As above, deffo the tongue & groove chipboard 18mm thick......secure the boards with twinfast plated screws 3.5mm x 35 - 40mm long.
Old Apr 20, 2006 | 01:32 PM
Mark B's Avatar
Mark B
no probs, looks like chipboard is the way to go, any ideas on prices?
How hard is all this to do as im a complete novice..... i.e the only thing ive ever built is a few bits of wood knocked together to stop the car falling on me...
MB.
Old Apr 20, 2006 | 01:33 PM
D19 STE's Avatar
D19 STE
Hopefully with it being a new house you should already have insulation up there, if not get some down before screwing the boards down
Old Apr 20, 2006 | 01:35 PM
Disabled Account
You built a wooden trolley jack?
Old Apr 20, 2006 | 01:36 PM
D19 STE's Avatar
D19 STE
MB.
Up my way a company called Jacksons Timber do the M/Resistant 8x2 Flooring for:-
18mm Ł4.00 per sheet
To give you an idea on the price the hardest part of that job is getting them into the attic other than that just make sure your screws go into the beams
Old Apr 20, 2006 | 01:52 PM
Mark B's Avatar
Mark B
D19 STE
Cheers mate, ye its all insulated, going up later to have a look about an measure it up, fitting sounds into my mates teg this weekend hopefully rope him into giving me a hand flooring the fooker,
MB.
Old Apr 20, 2006 | 02:11 PM
D19 STE's Avatar
D19 STE
D19 STE
MB.
Old Apr 20, 2006 | 02:15 PM
Old Apr 20, 2006 | 02:16 PM
Mark B's Avatar
Mark B
Old Apr 20, 2006 | 02:21 PM
PAUL S's Avatar
PAUL S
B&Q do specific packs of t&G chipboard for attics - cheap as chips as well
Old Apr 20, 2006 | 02:26 PM
sandyRS16i's Avatar
sandyRS16i
Yeah, thats what i'd recommend. The boads are quite small in size so dead easy to handle compared to the bigger sheets.
155lee
Sep 6, 2016 11:10 AM
Orion_Gav
Sep 29, 2015 04:50 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bassboy
Sep 10, 2015 08:54 PM
