Can you run two maps on a l8 ecu??
Hi just a question or two about mapping one of these brains
1/ Can you map/run 2 maps in the one brain?? Like a nice a safe daily setting and then a race setup?
2/ Whats the total number of injectors I can run with a L8 ecu..
Many Thanks indeed for any help..
for a std L8 ecu:
1) No
2) 4
it can be modified to run 8 injectors though with additional hardware from pectel or other.
my modified L8 can run 2 maps that can be swapped over with the flick of a switch and an 8 injector set up may be available later
it can also run distributorless ignition, closed loop fuelling, ALS or many other options.
1) No
2) 4
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
