coilovers on 3 door??
Old Apr 14, 2006 | 05:40 PM
moonstone mike's Avatar
moonstone mike
Default coilovers on 3 door??
Got some lede coilovers to go on my 3 door ....but i have many stories about the car being very skippy....do i sell them and get some new konis??? or is there a better set up anyone can suggest?
Help i need to sort out as the summer is coming
Old Apr 14, 2006 | 10:36 PM
ozcos's Avatar
ozcos
Most stories that are bad about coil overs are because they are fitted with to hard a spring. most second hand coil overs come from track cars and people fit them straight onto road cars and then complain they are to hard.
Fit the correct springs and you should have no probs.
Old Apr 14, 2006 | 10:43 PM
cossie604's Avatar
cossie604
also thru people not setting them up properly....there are plenty other settings other than FOOKING HARD lol
Old Apr 15, 2006 | 10:53 AM
lamb chops's Avatar
lamb chops
I have them on the front of mine and didnt like them when they were first fitted. Quite used to them now though.
I wouldnt fit them unless i had to, needed the arch clearance due to 18" wheels. Think the konis give a much better ride.
Old Apr 15, 2006 | 07:58 PM
moonstone mike
Old Apr 17, 2006 | 08:30 AM
RobS's Avatar
RobS
when mine were fitted i hated them, high speed handling was awesome but ride qaulity very poor, i need to change my springs on the rear cos there on soft and still skippy, and get alot of axle tramping when i launch hard.
if your just using it for road use i would stick with koni tbh
Old Apr 17, 2006 | 09:30 AM
moonstone mike
THIS is really pi55ing me off! i want to poly bush my whole car and fit new suspension next month!!
KONI
BILLYS
MY COILOVERS
OR ANYONE GOT A BETTER SET UP IDEA ?????????????????
HELP ME
Old Apr 17, 2006 | 06:39 PM
Wayne Ash's Avatar
Wayne Ash
I use koni shocks and ahmed springs on my 500 i set the rear shock to three quaters and the fronts on half and it works realy well and it dosnt bounce all over the road
Old Apr 21, 2006 | 03:29 PM
Ridgey's Avatar
Ridgey
SPAX PSX (adj damper) kit. Had them on my 3dr and was well impressed. The good thing is that you can adj both front and rear dampers with them on the car unlike the Koni rears that have to be removed.
Ł425 from Demon Tweeks i think.
Dave
Old Apr 21, 2006 | 04:22 PM
B11GNS's Avatar
B11GNS
Avos all round on mine, 300 lbs on the front and 200 on the rear
chowfornow
14
Jan 5, 2019 09:01 PM
mk1turboestate
Dec 2, 2015 08:31 PM
mpilk
Sep 27, 2015 09:21 AM
Adam Graham
Sep 6, 2015 06:04 AM
