braided hose and fittings
Old Apr 14, 2006 | 05:02 PM
xr4x4rs's Avatar
xr4x4rs
Default braided hose and fittings
wheres the best place to get this and the aeroquip fittings
need to get some for fuel lines
thanks
Old Apr 14, 2006 | 05:04 PM
Damo V's Avatar
Damo V
www.thinkauto.com
Old Apr 14, 2006 | 05:06 PM
Niall.b's Avatar
Niall.b
i got some from Webster race engineering, great service & pretty good prices too
xr4x4rs's Avatar
xr4x4rs
thanks mate
is it the tfe ones i need?
Old Apr 14, 2006 | 05:53 PM
Damo V's Avatar
Damo V
For fuel line get the tfe lined ones yes
Old Apr 14, 2006 | 05:59 PM
xr4x4rs's Avatar
xr4x4rs
ok sorted just found the prices
god knows how much ill need any suggestions
intank pump to fuel filter under car to fuel rail lol
is the standard banjo bolts for the fuel filter -6 fittment also where can i get the ends braized on for my both pipes on the pump
Old Apr 14, 2006 | 06:04 PM
Damo V's Avatar
Damo V
No tou will need new banjo fixings, or screw the fittings straight into the fuel filter
if you get a fitting kit for the pump it will have -6 fittings on the supply already....
for the return you could just use a hose clamp on the fuel tank, it isnt under pressure
Old Apr 14, 2006 | 06:10 PM
xr4x4rs's Avatar
xr4x4rs
ok thanks again mate
on the banjo fitting si wasa going to get new ones for the pipe to screw on im just wondering if the original screw would be the same size to fit into the new banjo if not then ill get a fitting that screw directly into it
Old Apr 14, 2006 | 06:36 PM
Niall.b's Avatar
Niall.b
a cossie takes 7 metres in total from filter to rail & regulator to tank if that helps
Old Apr 14, 2006 | 06:55 PM
xr4x4rs's Avatar
xr4x4rs
ok thanks
id proberbly need slighly more more than than that as my fuel pump and filter are in different locations but rekon i could get away with 8 metres
Old Apr 14, 2006 | 07:38 PM
Snowy_Astra's Avatar
Snowy_Astra
Originally Posted by Damo V
www.thinkauto.com
Quality website. Great for all the final fucking abouts on engines getting stuff linked up oil hoses coolers etc that are normally a pain in the arse to get
Nice one
Old Apr 15, 2006 | 05:02 PM
ricky's Avatar
ricky
JLS james lister & sons (motorsport)
in sanwell west midland pretty good but a bit pricey
Old Apr 15, 2006 | 06:33 PM
dojj's Avatar
dojj
Resident Wrestling Legend
i "unoffically" know someone who does a nice price at mocal
if you can get there they will make the stuff up for you on the spot, ut you have to know what sizes you want
spot on thoguh, but be prepared to pay a few quid, that stuff ain't cheap
Old Apr 15, 2006 | 06:51 PM
gibbo frst's Avatar
gibbo frst
i got mine at think auto.. also me bein a nob thought id get 7 meters and on one run from filter to fuel rail thought id best leave a bit extra to play with ended up with the other half too fukkin short.. went to buy more hose but they said bring the spare length in to them and all i had to pay for was half a meter... top place
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
bigluke200
14
Sep 2, 2015 10:35 PM
ekjim
Aug 27, 2015 05:20 PM
borboyous
Aug 22, 2015 11:17 AM
Escortdriver1
Aug 13, 2015 05:55 PM
