RRT lsd, wot oil best?
Old Apr 14, 2006 | 08:30 AM
Fiecos Dan's Avatar
Fiecos Dan
Default RRT lsd, wot oil best?
i've normally use normal hypoid 90 gear oil,
but 3 years ago i tried semi gear oil, and ever since the box has made a odd noise on engine braking, even after a flush and new hypiod fitted.
then last week a mate of mine sed someone told him, there's a oil thats better for the box,
is this true?
Danny
edited to read better.
Old Apr 14, 2006 | 08:40 AM
andre_k's Avatar
andre_k
are you assuming that the oil in the LSD is the same thats lubricating the box?
ring CTS, bernie can do what your after and will explain alot better
Old Apr 14, 2006 | 08:47 AM
NUTS RuS's Avatar
NUTS RuS
you can get them 'pumped up' with a thicker viscous fluid if thats what you mean... but you cant do it by pouring it into the box
Old Apr 14, 2006 | 08:57 AM
Fiecos Dan's Avatar
Fiecos Dan
i know the vicous is different oil, and bernie's done the centre diff on my cossie,
Just even tho, its seperate oil, ford still say lsd oil needed.
Old Apr 14, 2006 | 09:04 AM
NUTS RuS's Avatar
NUTS RuS
Try another edit - I still havn't got a clue what your mate means
Old Apr 14, 2006 | 09:07 AM
Fiecos Dan's Avatar
Fiecos Dan
ok,
Wot oil is best for the box. as after i used semi, i was told semi's no good for it.
Old Apr 14, 2006 | 09:14 AM
NUTS RuS's Avatar
NUTS RuS
?? what box ?? What car ??
Old Apr 14, 2006 | 09:27 AM
Fiecos Dan's Avatar
Fiecos Dan
Rst box with std lsd,
xr2tt in my sig.
Old Apr 15, 2006 | 08:04 AM
Fiecos Dan's Avatar
Fiecos Dan
BTTT please
Brickhouse
14
Oct 3, 2015 07:28 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
