where can you buy a spit roast lol for a cossie
not sure what there real name is but i mean one of those things that bolts to the body shell and makes it so you can roll the shell over onto it side etc
also would a 3 door one be able to fit a saph aswell
I think frost the restorers sell spit roasts.
http://www.frost.co.uk/productList.asp
under workshop. page 3 half way down.
cheers for the link mate that ideas out the window to much coin and the other one for Ł400 tilts it on its side which would of done the job except it has to fit to hubs so no good either as im now working with a bare shell
Originally Posted by DogSmoke
There is a "shell" on here who needs spitroasting apparently
Originally Posted by cossiecrew
im good at getting welding flash
on a serious note though ive got a mate whos prety good
Easy enough to make, I made one for a mini, but the main problem is finding what the mounting points on the shell are then just making stands to bolt to these. Just make the stands as wide as you can to give as much stability as my first attempt with a mini almost ended in disaster as one stand fell over as car rotated, fortunately mini not to heavy so held onto it till my dad could get a jack under the car. We then made then so they where slightly wider than the car and had no problems since.
Hope this helps
Hope this helps
lukeeboy149
Aug 22, 2015 04:29 PM
blakey100
Aug 4, 2015 08:17 PM
