zetec head
Old Apr 10, 2006 | 09:33 PM
b11lkw's Avatar
b11lkw
Default zetec head
how do i get the last 2 head bolts out of the centre of a zetec head without twisting and snapping the torx bits? they are incredibly tight!!!
Old Apr 10, 2006 | 10:52 PM
robbyridz's Avatar
robbyridz
decent torx bits shouldn't twist/ burr if they fit snug, and you have enough leverage - shouldn't be a problem.
I often find those cheap ones you get in sets are pants I've got through many of those.
I tend to buy hardened bits for common sizes, so I know they aint going to burr.
Old Apr 11, 2006 | 12:25 AM
jonnyturbo's Avatar
jonnyturbo
as above but another tip is to buy a long breaker bar for leverage, far easier to loosen stiff bolts, less likely to round the bolt or socket because you can undo it in 1 attempt as opposed to hitting and thumping your standard ratchet
Old Apr 11, 2006 | 03:14 PM
barry0777's Avatar
barry0777
ithought the 2 middle one where suposted to come out first????
Old Apr 11, 2006 | 03:58 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
yip mid 1ns should be first to come out
Old Apr 11, 2006 | 05:11 PM
b11lkw's Avatar
b11lkw
Default zetec heads
cheers guys, i did contemplate buyin a breaker bar but for some reason i didnt, the bolts under the cams came out ok tho. any advice on building a zvh turbo would be great
Old Apr 12, 2006 | 07:55 PM
Avinitlarge's Avatar
Avinitlarge
Default Re: zetec heads
The Bolts under the cams, Its easy to take the cams out, Then its easy to get to the head bolts
Old Apr 13, 2006 | 07:59 PM
b11lkw's Avatar
b11lkw
Default zetec head
well i bought a breaker bar and some new torx bits, i re-tightened the headbolts and sprayed wd40 on the centre 2, they still wont come out! the bolts are starting to round off so i have let be for now. the last thing i wanna do is resort to drilling them out.
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
RS-Rikki
Sep 21, 2015 07:27 AM
focuspower
Sep 20, 2015 03:51 AM
Chopshop85
Sep 18, 2015 06:13 AM
pie-face
Sep 15, 2015 10:43 AM
