rear springs
Old Apr 10, 2006 | 10:45 AM
Dicko&Vacant's Avatar
Dicko&Vacant
Default rear springs
im going to change the rear springs on the cossie today never done any before so how easy or hard are they to do its on a 2wd saff
Old Apr 10, 2006 | 10:47 AM
Neil S's Avatar
Neil S
Bit of a chew on mate!
If you're lucky:
Undo the exhaust from its hangers
Remove ARB clamps
Disconnect ABS sensors
Disconnect rear brake lines
Undo rear diff mount
Get old springs out with spring compressors.
You may have to remove the rear beam pickup bolts too.
Neil.
Old Apr 10, 2006 | 10:48 AM
Fiddy's Avatar
Fiddy
A mate of mine changed his on his 2wd saff cos, said it was pretty straight forward, but he is quiet handy with a tool kit.
Old Apr 10, 2006 | 10:49 AM
Fiddy's Avatar
Fiddy
Originally Posted by Fiddy UK
A mate of mine changed his on his 2wd saff cos, said it was pretty straight forward, but he is quite handy with a tool kit.
Old Apr 10, 2006 | 10:50 AM
Sticky.'s Avatar
Sticky.
Wheels off.
Undo shocks.
Undo Shafts.
Compress the old springson out.
Job done.
Me & Lee R21 done about 4sets on mine last year
Old Apr 10, 2006 | 10:53 AM
Neil S's Avatar
Neil S
That's what I tried, but it's easier to undo the diff mount (4 bolts, not 12 for the shafts), and getting the arms low enough to get the springs out meant that the rear brake lines were getting pulled taught
You can do mine next time!!!
Neil.
Old Apr 10, 2006 | 10:54 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Neil S makes it seems like a days work.
Paul makes it sound like you could do it standing on your head
Why such a mega difference?
Old Apr 10, 2006 | 11:03 AM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Dunno about a saff, did it easy enough on my old MK5 Escort. First time I jacked it tho I had the stand under the lower arm so I couldn't push it down to get the shock free
Old Apr 10, 2006 | 11:11 AM
Dicko&Vacant
ill have a go lol can c angle grinder coming out to play for time being
Old Apr 10, 2006 | 11:22 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Wheels off.
Undo shocks.
Undo Shafts.
Job done.
Aint that the truth Paul!!!
I think we got it down about an hour for the whole job from start to finish!
Make sure the springs are sat right in the bottom arm before you lower the car as it can make it sit all wrong otherwise!!!
Old Apr 10, 2006 | 11:25 AM
Sticky.'s Avatar
Sticky.
Just get the angle grinder on it
I reckon we get it in less than 30minutes now Lee
Old Apr 10, 2006 | 11:28 AM
Lee_R21Turbo
APMSL!!!! Yeah fetch it down here & Paul will lop a coil off with his angle grinder....makes the car sit perfect afterwards....well.....until ya hoof the loud pedal then you end up with a flat exhaust tip!!!
Oh & dont forget to use the purple touch up pen so the ends of the springs dont rust!!!!
Jim Galbally's Avatar
Jim Galbally
getting old springs out is normally tyhe hard bit. getting the new ones in is normally piss easy, as theyre gonna be aftermarket lowered ones, so they'll be shorter
cut the old ones out
Old Apr 10, 2006 | 11:34 AM
Dicko&Vacant
may resort to that when i lose my ( non existent) temper
Old Apr 10, 2006 | 11:35 AM
Sticky.'s Avatar
Sticky.
Oh my sides
Purple touch up pen was mint....im a big bufty
Old Apr 10, 2006 | 01:04 PM
Dicko&Vacant
one side done me and the fiancee lol not to bad of a job concidering never done em before now on to the next side
S3an
13
Sep 13, 2015 10:01 AM
Topjoe9
Sep 12, 2015 09:50 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
cossirob
Sep 3, 2015 09:17 PM
