Exploded drawing of 4x4 steering rack. pls
Can anyone help with an exploded drawing of 4x4 steering rack. I've had to swap parts from an xr4x4 rack on to the cossie rack and there seems to be uprated bushings in the cossie rack. Just wanted to check if that was right.
rob
rob
not too sure, but i do know that the bushes were apparently uprateable at some stage, don;t know if this was aftermarket or not though
the xr rack is esentially the same rack, you just need to make sure you put the right pipes into the right holes in teh rack is all
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
