RS TURBO HOLDING BACK, SHUDDERING AND POPPING PROBLEM?? HELP
I have a Series 2 RS Turbo which has developed a problem. It will boost then when you hit say 15psi it shudders and erally holds back, no power at all. The boost becomes erratic and usuall drops down. Sometimes it will pop and bang and go no higher than 10psi. I have tried a new actuator which hasnt helped. Any Ideas?????
check your boost hoses especially the one going from your metering head to turbo, found that mine has gone so soft it's collapsing as when the turbo comes on full boost it's sucking in lots of air and sucks the hose closed
also check your dizzy as these commonly go
Dave
Dave
also check the bottom hose from the intercooler, sounds like a problem i had that bugged me for ages an cost me a fortune till i found it.
_________________
this is a problem i have had too fixed with an alloy sleeve inside the hose
_________________
Billy_RS
16
Oct 11, 2025 09:41 PM
