Pro Alloy intercooler and EEC IV
Old Apr 9, 2006 | 10:56 AM
kennyA's Avatar
kennyA
Default Pro Alloy intercooler and EEC IV
Hi
Has anyone fitted the Pro Alloy intercooler with the EEC IV management and small turbo.
Where did you fit your air temp sensor?
I was going to buy a T-Peice Samco hose and fix the sensor with a jubilee clip.
anyone know or can suggest a better way? (drilling and tapping the plenum would be possible but the sensor could be influenced by heat from the engine).
cheers.
Old Apr 9, 2006 | 01:50 PM
sailorbob's Avatar
sailorbob
The back of the plenum (ie farthest away fom the head) would be fine, don't worry about the heat affecting the sensor as the air would be heated too.
Old Apr 9, 2006 | 01:58 PM
kennyA's Avatar
kennyA
cheers Sailorbob,
I'll check that out.
Old Apr 9, 2006 | 03:59 PM
THE RADMAN's Avatar
THE RADMAN
cant you just weld a boss on to the intercooler outlet kenny,would prob be easiest
Old Apr 10, 2006 | 07:26 PM
SafeChav's Avatar
SafeChav
Why don't you leave the IAT in its standard place just out of interest?
Old Apr 10, 2006 | 08:14 PM
kennyA's Avatar
kennyA
It can't go into its standard place due to the standard intercooler is not there. I need to find a location at the output side of the Pro Alloy cooler.
what happens if I just let the sensor read normal air temp? What are the normal?? temps seen at the output side of the small cooler on a small turbo escort?
Somehow I just don't see the outside air temp as a realistic option. I need to know more about the way the EEC IV is mapped to make a decision.
Old Apr 10, 2006 | 08:16 PM
Azrael's Avatar
Azrael
Put it where it would be on standard IC.
Old Apr 10, 2006 | 08:37 PM
SafeChav's Avatar
SafeChav
Ah right this Escos were talking yeah? I was thinking FRST sorry
Old Apr 10, 2006 | 08:44 PM
kennyA's Avatar
kennyA
Azrael
This would be the better solution.
Safechav
No need to apologise, I didn't say Escos in the first post.
Old Apr 10, 2006 | 11:30 PM
sailorbob's Avatar
sailorbob
The IAT (or ACT if you prefer) has to go after the intercooler. The COSY eec-iv uses the sensor for corrections/control for spark timing, fueling, volumetric efficiency correction, boost control, adaptive learning control, cranking fueling and some other stuff I don't know about (but not the idle for some strange reason on the COSY ecu). For the eec-iv to make the correct decisions the input has to be the temperature of the air entering the cylinders, anything that raises (ie turbo) or lowers (ie intercooler) the temperature of the air has to 'sit' before the sensor in the induction route.
Old Apr 11, 2006 | 05:36 PM
jon@work's Avatar
jon@work
I had a boss welded into my EEC4 plenum for use with weber management
Old Apr 11, 2006 | 06:40 PM
kennyA's Avatar
kennyA
Nice job.
Fudgey
21
Sep 30, 2015 06:19 PM
