COSWORTH NOT STARTIN, BUT HAVE SPARK!!!!??
Old Apr 7, 2006 | 07:30 PM
vinnyd's Avatar
vinnyd
Default COSWORTH NOT STARTIN, BUT HAVE SPARK!!!!??
HELLO ppl
right i have changed my phase sensor and crank sensor, but it still wont start!!
i find this really funny cos i have a spark from my coil but it wont find its way to the plugs but i do get a spark on plug 4???
there is fuel and the car is tdc, i have used this led tester and i am getting 1+1 and 1+3 back i think this is crank sensor and timming, but i have changed the sensor and the car is defo tdc!!
does anyone know a good auto elec from liverpool or cheshire way..
or does anyone have any ideas what this could be...
cheers.
Old Apr 7, 2006 | 07:35 PM
jon@work's Avatar
jon@work
TDC is when the lug on the crank pulley lines up with the marker, and not the notch - you have got this correct, haven't you ?
Old Apr 7, 2006 | 07:45 PM
vinnyd's Avatar
vinnyd
hey jon, thought u had fell out wid me..haha
yeah i have lined it up with the fist lug after the notch, but it was not like that it was defo 30 deg out, but now its defo TDC,
i left a gap ov 0.30 for the crank sensor but it didnt wanna spark so i had to move it closer, does that seem right to you, plus i have a gap on the phase sensor ov 0.80.
Old Apr 7, 2006 | 08:50 PM
jon@work's Avatar
jon@work
crank sensor gap should be 0.6 - 1.0mm
phase sensor should be less - IIRC, about 0.3mm
So you've gone through the diagnostics again, and everything's OK ?
Old Apr 7, 2006 | 09:15 PM
Alvyn's Avatar
Alvyn
have you put the wire to phase sensor the right way round?
Old Apr 7, 2006 | 09:48 PM
vinnyd's Avatar
vinnyd
yeah, thats on right i have been all throught this b4, i have tried everything, the car is sparkin but not enough or not strong enough??
it will spark for about 10 turns then go dead and then start sparking again!!??
Old Apr 7, 2006 | 09:58 PM
vinnyd's Avatar
vinnyd
yeah i have been through it loads a times now, its like it wants to start now but can not hold the spark, i had it ticking over but then died on me. and it has not run since then..
you know how much ov a hard time i have had wiv this car..
i dont think its a wiring fault cos i am getting all the right readings back to the ecu.. but that led tester i got off a mate keeps coming up with crank sensor and phase sensor but i have set them to the right gap..and changed them to all other values.
Old Apr 7, 2006 | 11:10 PM
jon@work's Avatar
jon@work
you haven't got the phase sensor and crank sensor plugs the wrong way round have you - the white plug goes to the crank sensor, black to dizzy
Old Apr 8, 2006 | 08:17 AM
vinnyd's Avatar
vinnyd
jon am not that bad hahah..
Old Apr 8, 2006 | 09:29 AM
jon@work's Avatar
jon@work
Vinny - ABS loom, say no more
Old Apr 8, 2006 | 09:49 PM
vinnyd's Avatar
vinnyd
am going to ignore that one J..lol
I done that check again to be sure from secs post, and i am NOT getting any AC voltage back fromt the phase an crank sensor!!! now i have set the sensors to the right gap, but if i set the crank sensor at the right gap i dont get a spark, but if i move it closer then i get a spark???
i should not imagine that this t a great problem, but even when i do get a spark i dont get an AC voltage still!!!
jon you must know someone who i can pay to come and fix this..lol
Old Apr 9, 2006 | 10:06 AM
biglee's Avatar
biglee
Audio specialist
to get a reading off a crank sensor or phase sensor you will need an ociliscope or a very acurate analogue volt meter that reads nano volts, if you a are getting a spark to start with, then none at all after its started then you have a coil voltage problem, ie the coil is not going to full voltage after cranking as the coil runs at 12.8 volts during crank then 9.9 volts after the car has started, if its not getting the correct voltage it will not create an intense enough spark, bear in mind that being 1 volt out on your coil input voltage means 200 volts diferent on the output voltage, as they are ineffect a step-up transformer.
Old Apr 9, 2006 | 01:01 PM
vinnyd's Avatar
vinnyd
the meter am using is a good one i got it from work i am getting a spark on plug 4 but it will not spark to the others!
i thought the voltage from the crank sensor is about 2vac and the same from the phase sensor but i think its about 4.5vac from that???? i got this of a post secs,
when i just use the HT lead to see how strong the spark is its fine, but it must not be strong enough to transfer to the leads??? does that make sense!!!
Old Apr 9, 2006 | 03:53 PM
vinnyd's Avatar
vinnyd
sorry lee your right i can not use a meter to measure the voltage on them, i will have to get ociliscope to see if i am getting a signal, but if i am then its got to be the coil of ig amp modual..!!!
Old Apr 9, 2006 | 11:48 PM
biglee's Avatar
biglee
Audio specialist
quite correct matey, it could even be somthing as simple as a bad live feed to your coil, or a bad earth on your ignition modual, good luck mate ...Lee
Old Apr 10, 2006 | 01:18 PM
BMEP's Avatar
BMEP
Default Re: COSWORTH NOT STARTIN, BUT HAVE SPARK!!!!??
HELLO ppl
cheers.
If you are getting spark from the coil lead but not from the dizzy, it may be a faulty rotor button or dizzy cap.
Hope you get it sorted
Old Apr 10, 2006 | 04:09 PM
vinnyd's Avatar
vinnyd
i have changed the rotor arm... cheers anyways..
Old Apr 23, 2006 | 12:53 PM
280's Avatar
280
hi m8
you havent tried changing the chip have you and maybe put it in wrong thus blowing the ecu and ign amp anyway just a thought
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Aug 14, 2015 07:29 AM
adriansaleem
Aug 1, 2015 09:28 PM
