ERST Cooling options with GRS and Kenlowe fan.
Old Jul 31, 2004 | 09:26 PM
L33 BYT's Avatar
L33 BYT
Default ERST Cooling options with GRS and Kenlowe fan.
Right been thinking of cooling options for the RS. The way I would like to do it is as follows just need to get wiring confirmed.
I would like to keep the original cooling method but also add a dash board switch for those POD runs or sitting in traffic until I trust the setup!
So whats the best way of doing the wiring for it?
Do you make up a new loom or can I chop into the existing.
Old Jul 31, 2004 | 10:33 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Default Re: ERST Cooling options with GRS and Kenlowe fan.
My life is enlightened now you have told me that. Thank you very much
Old Aug 1, 2004 | 12:01 AM
Stu.H's Avatar
Stu.H
Old Aug 1, 2004 | 12:07 AM
DazC's Avatar
DazC
If only you knew that sooner Tony!!
Old Aug 1, 2004 | 09:21 AM
L33 BYT's Avatar
L33 BYT
Feel a bit of a thick twat. I forgot to put in the whole point of the post.
Old Aug 1, 2004 | 12:08 PM
Stu.H's Avatar
Stu.H
Old Aug 1, 2004 | 01:07 PM
DazC's Avatar
DazC
PMSL...
On the Cossies, I make a complete new loom which replaces the Ford wiring but still utilises the fan switch and the fans. My own Series 1 has a seperate control loom for the fan using the Ford fan switch but I never fitted an over ride switch....
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
