cossy timming marks the 2 arrows on the cam pullys that face
Old Apr 6, 2006 | 05:43 PM
abdr500's Avatar
abdr500
Default cossy timming marks the 2 arrows on the cam pullys that face
cossy timming marks the 2 arrows on the cam pulleys that face each other 1 all ways seems to move off slightly when I tension the belt so I put verniers pulleys all sorted now. but why is that .it only moved very slightly car run perfect even if it was like that but. why
Old Apr 6, 2006 | 05:44 PM
because the distance between the pulleys isnt an exact number of teeth on the belt.
especially if head has been skimmed
Jim Galbally's Avatar
Jim Galbally
becase there was slack in the belt between the 2 pulleys when you tightened it. it needs to be tight, then you release the tension on the belt.
Old Apr 6, 2006 | 05:54 PM
abdr500's Avatar
abdr500
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
