Carring on from YUM'S thread
Old Apr 5, 2006 | 11:21 PM
JohnnyB's Avatar
JohnnyB
Default Carring on from YUM'S thread
I was just thinking of the Physics of 2.0l engine what is the limit, My thoughts is there is a limit. There is only so much air (not oxygen) you can push into 2.0 engine no matter what the V.E. the engine has. So what is the limit forget fuel, is 1000 bhp possible. I think it cannot be done with out adding oxygen eg NOS
Your Thoughts?
Old Apr 5, 2006 | 11:25 PM
GARETH T's Avatar
GARETH T
1000 BHP would be easy to hit
the only thing that limits a turbo engine is its mechanical strength and heat (words of a much wiser man than me )
Old Apr 5, 2006 | 11:56 PM
89xr2's Avatar
89xr2
Brap!
In theory, if you could build something like a billet block, special rods, pistons etc and money was no object how high could you get the power? Surely the limiting factor would be the valve size? Or could you just keep upping the size of the turbo to force air into the engine at higher pressures?
Old Apr 6, 2006 | 07:24 AM
JohnnyB's Avatar
JohnnyB
Correct me if I am wrong, but you can only compress a certian amount air in a confind place. eg there will be a point were the cylinder cannot take any more Air?
Old Apr 6, 2006 | 09:15 AM
It's Czech Mate's Avatar
It's Czech Mate
If you compress it enough it will turn to liquid. I'm sure a turbo couldnt produce anywhere near that kind of pressure tho. I doubt thats going to be the limiting factor
Old Apr 6, 2006 | 11:02 AM
Cossiebros's Avatar
Cossiebros
That will be mr. Duckworth i presume
If you look at the BMW F1 turbo engines, the limiting factor was not the amount of air, but fuel. I've read somewhere they needed to use rocket-fuel in these engines and managed 1400BHP on 1500cc.
Also, top-fuel dragsters manage something like 1000BHP per litre, so if u could use whatever kind of fuel and reliability is not important, 1500 BHP could be possible. More realistically, i think 1000BHP would be the limit.
Old Apr 6, 2006 | 11:13 AM
Neil S's Avatar
Neil S
Surely, assuming an ideal physical engine, it depends only upon max RPM, and the burn speed of the fuel?
Neil.
Old Apr 6, 2006 | 11:15 AM
GARETH T's Avatar
GARETH T
burn speed would dictate the max rpm!
Old Apr 6, 2006 | 11:16 AM
big_wig_074's Avatar
big_wig_074
but once you reach the limit of how much you can put in you add revs! so MORE power!
Old Apr 6, 2006 | 11:20 AM
JohnnyB's Avatar
JohnnyB
so If you pump 1000 psi in a engine of say 2.0l you will need to to rev like a bastard to consume the air.
so if your rev limit is 7k there is a limit correct?
Old Apr 6, 2006 | 11:25 AM
89xr2's Avatar
89xr2
Brap!
But if, in theory you could make the components/engine bullet proof it could withstand silly revs not just a measly 7k
Old Apr 6, 2006 | 11:27 AM
Neil S's Avatar
Neil S
Gareth - what would happen if you changed the size/shape of the combustion chamber?
Less volume=less time for the flame front to hit the piston=higher rev ceiling?
Old Apr 6, 2006 | 11:31 AM
GARETH T's Avatar
GARETH T
not really,, you would have a higher comprssion ratio,, so you would really need more advance in there aswell
Old Apr 6, 2006 | 11:41 AM
Neil S's Avatar
Neil S
Cool
Neil.
It's Czech Mate
I'd reckon on heat and the fueling at high rpm would be the problem
Old Apr 6, 2006 | 11:47 AM
Rick's Avatar
Rick
it's a but pointless this thread. if u take out, heat, flow limits of the head, strength.... then the power output becomes infinite lol - the capacity has sod all to do with it.
Old Apr 6, 2006 | 11:48 AM
JohnnyB's Avatar
JohnnyB
Yes Rick is right.
Old Apr 6, 2006 | 12:00 PM
old formula one turbo engines made 1400bhp or so from 1.5 litres
next question?
LOL
Old Apr 6, 2006 | 12:09 PM
JohnnyB's Avatar
JohnnyB
yes chip I was being a bit thick forgetting the fooking engine REVs just focusing one on cylinder stroke
j.hammond1
30
Oct 31, 2021 05:28 PM
PhoneShopRS
PassionFord FAQs
Nov 5, 2020 06:50 PM
s1cab
Jul 26, 2018 06:11 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
vdubo7
Aug 2, 2015 08:17 PM
