4wd cosworth transmission what power
Old Apr 5, 2006 | 03:29 PM
xr4x4rs's Avatar
xr4x4rs
Default 4wd cosworth transmission what power
its been asked before but what would be the max power this transmission can take
no hard hard launches as i will limit myself not to this time
as i had 330 before and kept destroying 2nd synchro
i will be running 3.6 diffs aswell if that makes any difference
ill be looking at aroung 450bhp for the engine will i get away with it if i treat it nice and no hard launches
Old Apr 5, 2006 | 03:31 PM
stonehavencossie's Avatar
stonehavencossie
Most people say 350bhp is its limit
However, ive thought about going above this and asked around before.
If you treat it with respect then 400bhp can be ok.
Not sure about 450 though ?
Old Apr 5, 2006 | 03:43 PM
Damo V's Avatar
Damo V
I would like to see anybody buy/build a 400 brake engine then treat the gearbx with respect ...
Might aswell leave it std
I blew mine with 320 brake... anyway its torque that matters..
Old Apr 5, 2006 | 03:46 PM
xr4x4rs's Avatar
xr4x4rs
so im going to ned uprated box and diffs then
Old Apr 5, 2006 | 03:48 PM
Damo V's Avatar
Damo V
uh hu I should add I stripped third gear... so wasnt launching
Old Apr 5, 2006 | 03:50 PM
xr4x4rs's Avatar
xr4x4rs
i did that aswell and snapped the main shfat just by changing from 2nd to 3rd at 30 lol
i can get a skyline box cheaper but duno how much the bell housings are
Old Apr 5, 2006 | 03:57 PM
Martinshuter's Avatar
Martinshuter
i have just stripped 3rd gear in my 400bhp saff so id say think about a gearbox upgrade first.
Martinshuter
Old Apr 5, 2006 | 03:58 PM
Dave Henshall's Avatar
Dave Henshall
how much and what sort of work is there in going sktline box route...?
Old Apr 5, 2006 | 04:00 PM
DaveEscos's Avatar
DaveEscos
whatever power, if you're going to launch the fuck out of it, its going to break.
If you're treating it well.. then I guess 350- 400 will take its toll.. if you have big boost peaks (read.. high torque)
Old Apr 5, 2006 | 04:01 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i keep killing boxes in my stage 3 saff
They get really noisey on over run in 3rd 4th 5th, sounds like the box is falling out.
xr4x4rs's Avatar
xr4x4rs
as far as i know you have to have a 4wd bell housing welded onto the box , make the transfer box in the tunnel wider and obviously gear box mounts aswell
then just have props made up to suit the box
but i have no idea how much it costs, i can do the tunnel myself and the get the props done at a local company or zoo motorsport
just dont know about the bell housing or mounts
Old Apr 5, 2006 | 04:03 PM
JTECH James
Passion for Fords!
Speak to Martin Reyland he does those skyline conversions i think
Old Apr 5, 2006 | 04:04 PM
Damo V's Avatar
Damo V
AFAIK, Martin Hadland had a bellhousing made to order
Old Apr 5, 2006 | 04:06 PM
JTECH James
Passion for Fords!
yup i meant martin @ reyland
Old Apr 5, 2006 | 04:11 PM
Dave Henshall
is it a tried and tested route and is it cost effecient in comparison to a fixit kit with a decent clutch and hydraulic conversion...?
Old Apr 5, 2006 | 04:13 PM
xr4x4rs's Avatar
xr4x4rs
ive just spoke to reyland they said there not going to do it anymore unless its the oskein box
so looks like im going to have to look at another route now
Old Apr 5, 2006 | 04:18 PM
rog's Avatar
rog
What i'm interested to know is, firstly, when people destroy there boxes with stage 1 and say the boxes are shite, they forget to mention that the car has done about 120k, I blew a greabox into a million bits before, it's not that hard, car had done +80k, got a new box, turned up the boost and it hasn't given me any bother and i do launch it regularly, off traffic lights! Car is just stage 3 BTW. I think 400 would be ok, but not if u just used it for trackdays etc.... time will tell i guess.
Old Apr 5, 2006 | 04:19 PM
Damo V's Avatar
Damo V
Also depends on tyres clutch suspension etc..
Azrael's Avatar
Azrael
Default Re: 4wd cosworth transmission what power
I fail to see what synchros have to do with power. Revs and rations if anything. But you would probably destroy them the same if 200bhp and 400bhp, it's a matter of how you change gears.
Old Apr 5, 2006 | 04:30 PM
xr4x4rs's Avatar
xr4x4rs
ok i had stage 3 the gearbox had just been reconned aswell
i had alcon 6 paddle clutch the car did used to get launched aswell
i didnt fast change as it didnt like it so i only doen slow change itwas always 2nd gear sybchro sumtimes 3rd and kept doing my head in when the car was off teh road every 2 months for gearboxes now im thinking of upping thge power i need the car to reliable as its everyday
Old Apr 5, 2006 | 04:33 PM
Azrael's Avatar
Azrael
xr4x4rs itmust be something with gearbox assembling, or gearchange or gearbox oil. I hae no idea how power could influence synchro wear. One or two misshifts can fuck the gearbox up though.
Old Apr 5, 2006 | 05:04 PM
xr4x4rs's Avatar
xr4x4rs
i know thats what kept getting told aswell
well im going to give it ago with standard boxe and diffs but have them checked over before fitting possibly get the box shot peened i will take my time and see how it goes when it goes i will upgrade but at the minute i carnt afford to
Old Apr 5, 2006 | 05:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
4 boxes
8 rebuilds
in 18 months
i should have bought a quaife box in the first place
one of my "NEW" boxes lasted a total of 23 miles before it went tits up and that was in fifth going along the motorway and not even giving it mucho beans
mind you, the original box i lost 4th gear in
then the next box i scrapped at one of the revs days at brunters
but i've never had 3rd gear go (but i had put cogs out the side casing of the box before and fook me thats something you never want to do )
i did get a guy to build me a box when me and mob did our 5th gear top end mod and that was fine no matter how hard i ragged it
pity the engine made like a chocolate firegaurd and melted 3 weeks later
is there any way that the T5 can be made to get 4wd then?
Old Apr 5, 2006 | 05:25 PM
Smit's Avatar
Smit
The 60ft Launch King
Originally Posted by dojj
4 boxes
8 rebuilds
in 18 months
When my box went the first time it was 3rd gear. It distroyed the whole gearbox as the debris floated round in the moving parts!
Then got another box built by Bernie and how it survived 2 years of my constant abuse before 3rd went AGAIN i will never know
Think it all depends on your driving style. I really have no recpect for my transmission and it done well while it lasted
Might be worth a E-Mail/Phone call
Old Apr 5, 2006 | 05:32 PM
xr4x4rs's Avatar
xr4x4rs
i phoned cts up today and they said i would be advised to go quaife box and diffs but looking at 6k which tbh i have no where near that at the minute
as ive said wim going to have to leave it alnoe for now and treat it gently if it goes it goes but no harm in trying with what i have
Old Apr 5, 2006 | 06:25 PM
dojj's Avatar
dojj
its cheaper to rebuild evertime
but it does take the piss when you are on the back of an aa wagon 6 times a year
Ridgey
Aug 30, 2015 08:37 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
