Sarting Problem From Cold S2
Mines the same, just found the fuel injection module thingy's fuse was blown
but that's prob not the problem you have!
Try disconecting the cold start valve, when cranking it will flood the engine, see how it goes then.
but that's prob not the problem you have!Try disconecting the cold start valve, when cranking it will flood the engine, see how it goes then.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Russ Payne
Sep 25, 2015 08:29 PM
aint got a clue why though
