speaker size in sapphire (4x4)
Old Apr 5, 2006 | 07:04 AM
gingeRS's Avatar
gingeRS
Default speaker size in sapphire (4x4)
what size are the dorr speakers and rear shelf speakers in my 1992 sapphire 4x4 cos?
wanna replace them, but keep it all looking factory, so i can use the grills etc.
anyone have any experience of this at all?
cheers
Old Apr 5, 2006 | 09:57 AM
TurboShed's Avatar
TurboShed
Cossiemodo
If you do that you will only be able to get away with tiny speakers, if you replace the grille's you can go up a size, tight fit mind.
Old Apr 5, 2006 | 11:50 AM
gingeRS's Avatar
gingeRS
want to do it with as least chopping neccesary, also so they are hidden.
are the fronts, 4's or 5 1/4's?
and the rear shelf??
is depth an issue with the doors, so they dont hit the window glass etc
Old Apr 5, 2006 | 02:53 PM
TurboShed's Avatar
TurboShed
Cossiemodo
I think they're about 11mm, they'll fit ok re. the door frame I think, with larger speakers, without original grille they can fit but have to be positioned just so.
Old Apr 5, 2006 | 03:54 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I have 5 1/4's in my doors, I only had to trim the plastic lugs that hold the grille on the door card and drill a couple of holes in the door for the speaker screws.
Window clearance is tight, but the speakers have a pretty hefty magnet, others may not be soo deep.
Old Apr 5, 2006 | 09:49 PM
jason_nike's Avatar
jason_nike
I made some mdf rings for the front, covered them in black acoustic cloth, then screwed through the original door holes to the mdf, then fitted the panel. Then I fixed some pioneer ts1799s to the rings. When I remove them no extra holes will be left
Old Apr 9, 2006 | 04:25 PM
iansoutham's Avatar
iansoutham
OCD Victim
Have just finished doing this exact mod to my 4be. If you use some Corsa 1993 onwards spacer rings, you can fit 5 1/4 inch speakers behind the front door cards without even having to touch the grilles on the card itself.
In the rear, if you carefully remove the grill, you can unscrew the original speakers and fit 5 1/4 inch speakers in the rear as well. You cannot go too proud though or the original tweeter will cause problems upon refitting. You will also have to fabricate a mounting system for the parcel shelf speakers as the originals were held on with bolts through the middle.
Hope this helps.
Old Apr 10, 2006 | 09:15 AM
gingeRS's Avatar
gingeRS
Hope this helps.
cheers
so corsa 1993 spacer rings to get 5 1/4's in the front
truffleshuffle
Sep 10, 2015 09:35 PM
Mk5brown
Sep 9, 2015 12:52 PM
Tony W
Sep 9, 2015 12:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
